89-ish K5 build. Beat cancer!!! Time for icecream!
3 Link front, leafs in the rear, 2.5" ADS Racing Shocks!
Easiest / cheapest way to brace the steering box is with another frame section.
Cut it out with plasma/ grinder.
Then stitch weld and rossete weld it in.
I'll have to make a small bridge piece to the other plate but oh well. My fault for not grabbing enough of the frame.
Nice! I got two front frame sections saved for that exact same reason.
What thickness did you go with? Any reason you didn't double weld the hoops and plate up to them?
Got the lower shock mount done on the driver side. Don't know why but it took me 3 tries to get it right. Oh well the tuition pile grows.
lol
Looks like I should be fine for coil clearance to steering shaft.
Hopefully I can spend a few hours out there tomorrow and get the hoop in place and upper brackets made.
Since your in there I'd run a brace from the top of the frame to the shock hoop. I realize your gonna run a crossbar too but I know this truck will see air too
Yah i guess I should say done is a relative term. I have enough tube for the hoops and the crossbar. Need to finish chopping up the k5 tub that's on my trailer and go and get more tube.
