89-ish K5 build. Beat cancer!!! Time for icecream!
3 Link front, leafs in the rear, 2.5" ADS Racing Shocks!
Build two sets of boxes to close those shock mounts in and send me the other set. I have been lazy and just been running mine with cardboard and old blanket to keep the dust and stuff out of the cab. LOL
You adding air bumps and better shocks?
Just really the bumps. I had to torch off the shock tabs due to the fact that I cut and turned the diff, and lost the zero rate. The rear will have the same 12" 2.5 ADS shocks, plus air bumps. The front just needs air bumps put in.
Not a lot done today. I cleaned the shop a little, then made it dirty again. I attempted to make a driveshaft but forgot the driveshaft is at its longest at bump , not droop in the rear. So driveshaft attempt number two tomorrow. Good news is I have plenary of angle and no bind, but was not happy with only 2” of spline engagement at full bump. I did get the packs back together, and u bolt plates cut down so you can actually get a wrench on them. Then I welded in the bump pads. Back at it tomorrow morning before the Wife and kids return.
With those soft leaf springs you planning on a traction bar?
What are you doing to the wagon?
Yeah track bar brackets are still on there from green thing. I have the track bar too, just need to cut it down and throw a new heim on it. The wagon is getting a locker in the rear, new exhaust gaskets, and all new front end parts( Tre's and Ball joints) .
