89-ish K5 build. Beat cancer!!! Time for icecream!
3 Link front, leafs in the rear, 2.5" ADS Racing Shocks!
@jekquistk5 pics of upper shock mounts? I am sorta stuck on what to do back there for mine. The rear is moved quite a ways back, and there isn't a ton of room in between the spring plate and drum. I was thinking tall mounts on the tube, but unsure about the upper mounts.
Looks good Jesse! You'll have to take me for a ride and see how much better your rear springs are than mine. ha ha
Thanks Heath! I know it’s not pretty with dimples, but it’s not a race truck so I’m fine with the simple functionality of it. I pick up my nitrogen tank on Monday then I can fill the shocks and bumps and start testing.
Also if anyone is looking for a no loss shock tool kit hit up baja mike on instagram. 65 shipped to my door.
I now do not have to rely on others to charge my shocks. 20cuft tank with Harris regulator. Need to change the hose to higher psi rating but for 100 bucks for a full tank with Harris regulator I couldn’t beat it
Finished up a bunch of little things and started taking her for little shakedowns. Hit the front ditch of my house at 25-30. This is gonna be a fun truck. Turns out I need a new alternator and a few little things but all in all feel real good about the truck.
We’ll beat on it at the dunes. It still has a long way to go, but man am I happy. I can keep up with dueling which is all I wanted for this thing, but it has way more potential. At the end of the week I drove it on to the trailer with no real carnage except it wouldn’t go into park. The bushing on the frame let loose and was causing the linkage to go caddy wampus. Manually put it in park and called it good. I really need a cage, seats and shock tuning. I called ads, and my shocks have the standard 12/15 pyramid style valving. So I will up the medium and high speed to .020 instead of .015. That should help the g outs, but getting a cage an nice seats in first.
Here is the video Heath talked about.
If you listen at the end you can hear how pumped we were. I can honestly say this was the most fun dune trip I have had!
