I suppose I should try that first. It's probably just plugged with dirt.
Scott I moved the box forward on one of my old blazers. its a ridiculous amount of work and best done with the fender completely removed.
The biggest problem is running into radiator. I moved my up and forward because just moving it forward would have put it too low. Although I moved it quite a ways and it looks like you might be able to just go an inch or so.
We bought a new TDI Jetta for her to drive last year and it's a 6spd manual.So your wife can drive the manual? That's handy.
Martin
The other thing I had to do was bleed the brakes. A lot of times I'm doing this work by myself. Even if the wife is around, she won't help because she has helped me bleed brakes before and she doesn't like it at all. It's too boring and monotonous. So a while back I purchased a Motive Power Bleeder. It works really nice for solo brake bleeding.
I'm pretty sure that's water contamination as brake fluid likes to absorb moisture. I had to refill the reservoir and suck it back out a couple of times to get the junk out. I should have taken an after picture because the fluid in there now is a much lighter color than the stuff that was sucked out.
Thanks for the pictures; they are handy for thinking things over. I can see where heim joints could help me gain some clearance without changing anything else. But I've never been sure how good they are on a street rig. I did have them on the tie-rod on my K5 but it was trailered a lot.I had a similar issue with my off-road rig after pushing the front axle forward about 3" ended up going with a custom heim joint steering set-up but I don't think that would help your set-up. I think the best way to fix this is by doing something different with that tie rod. Sucks to redo the hydro assist but is still way better than redoing the steering box. Here's a pic of my steering on the off-road rig just to generated some ideas maybe.
I believe it is the Superlift arm. I got it seven years ago with a NWF crossover kit.The biggest issue with moving it Scott is the radiator clearance. I moved my box up you can see it in this pic
I moved the box up and forward that drop pitman arm is the superlift one that everyone uses part #1104 I think? 4" drop arm for a bronco.
It looks like you could go about an inch and have gobs of clearance. My box was butted up against the body mount. Could not have gotten it more forward without moving the body mount. You can also see where I cut the frame for pitman arm clearance
