Thanks!
I finally got one of the shocks mounted.
Arg, I hate when I notice a place I missed with the paint when I post up project pictures.
Big hindsight item was that I should have got the spacers for 1.5" between the tabs instead of 1.25". The unfortunate thing is the 1.25" spacers are a heck of a lot less expensive. In order to make things work, I had to cut down the mounting tabs so they have the minimum amount of material above the holes. The unfortunate thing is I forgot this when I welded the tabs to the axle and i had to cut them after the fact and they look kinda hack.
I'm debating about torching them off and welding on new tabs. Can't decide if it's worth the effort.
Here are a couple pictures of the second side in process.
I decided to use existing holes in the frame which ended up making things harder. If I had it to do over again I would make a plate that would bolt to the frame the entire length between the 2 holes I used above. And then weld everything to that, namely shocks and bump stops. This would have given me more versatility and done a better job covering up all the holes.
I used a 4" hole saw to cut the hole in the fenders. On the passenger side I tried to make 2 holes to make a nice looking cut. But the hole saw didn't cooperate and I had to finish it off with a sawsall. So the one side is not quite round.
In order to figure out where to put the hole, I used a plumb-bob, or a weight on a string. Marked the inner fender where the weight lined up with the axle. The 4" hole saw gives me room to clear the 2" diameter shock with some room for error as well.
The passenger side should go a little quicker. One, because this is the second time around, and two there is less stuff in the way on the passenger side.
How high does your hoops come off the frame rails? I hope I can fit a cross bar between the hoop as well.
