Do they attach to the vent window too?
Yeah, I thought the same about being tighter to the body. The other mirrors sucked for towing anyway. I need to get one of those mirrors that attach to the end of the regular mirrors.Ninjas!
I really like the mirrors. They are nice and tight to the side of the truck. Great for everything but pulling your camp trailer. Do they attach to the vent window too?
Do you think the stock mounting point is in between the top to original holes? I really wanted to use at least one of the original holes and I felt like the forward most top hole worked fine so I didn't try the rear most top hole.His are actually mounted forward of the stock placement. The do overlap the glass but there are no attaching points above the door skin / belt moulding.
Go to a steel recycling place.Imagine how much heavier it would have been!![]()
I was just looking around the yard for some scrap to haul. Unfortunately we just cleaned everything out a couple weeks ago. I might have to wait a couple more weeks to get another pile going.Go to a steel recycling place.
You get paid for weighing the truck
I would think about trying to get a set like yours on the truck but I'd have to find them at the junkyard; they're pricey new. Plus I think they are probably easier to mount on tube doors than factory doors.See, and everyone laughed at me at my first BB for having newer elephant mirrors. Their nice huh Scott. Smack them on anything, so what, fold them back out.
and yeah, maybe I didn't have a CB my first year, but the mirrors were more important at the time![]()
If your soldering iron isn't heating fast enough, or hot enough, you will be frustrated as fork!!I'm trying to be a good little gearhead and solder my wires together, but it's making me want to hulk-out and throw shit.![]()
I thought about that, but I'm thrilled about learning a new technique.Use a torch
These are 10ga wires and I was trying to use the pencil iron with the pointy tip. After posting I did some searching and found I should at least be using a wedge tip - which I don't have. I went ahead and bought a Weller soldering gun that does 100W/140W. I also bought some .060" solder because I was trying to use .030" which I was thinking didn't help on the big wire.If your soldering iron isn't heating fast enough, or hot enough, you will be frustrated as fork!!
But I can tell you that after doing repairs to the electrical on mixer trucks, I don't feel the need to solder every connection on my personal stuff. At work, I have seen so many wires fail from vibration, and quite often just 1/2" from a connection or farther. The connector held, but not the insulation and wire. Now I will concede that the water, cement, and acid cleaning don't help...
So I look at what circuit and where the wires run, then decide.
Moving from a plug in pencil iron to a temperature controlled weller iron is like going from a small block Chevy to an LS. Night and day difference.I thought about that, but I'm thrilled about learning a new technique.
I do think I was trying to use the iron too cold. I was in a hurry thinking I could solder the wires quick on my little break away from the computer. Problem was I had to hold the iron on the wires so long I was getting the entire length hot and softening the insulation. Then I think because the iron was too small I was only getting good solder on one side. When I tried to do the other side the solder started to release. My clamping device is broken so I was trying to do this all without holding my work securely.
So it was really all my fault but still frustrating.
