I haven't done the driver door, maybe that one could be AD3500. Although my A and D wouldn't match.
I'd imagine fighting the Red Baron with overhead levers. Making airplane and pewpew noises.
I do put a little silicone on it.Good news! No engine oil spots appearing on the ground!
Bad news, passenger axle shaft flange is leaking. Ugly wheel proof
I have replacement metal shim thingy. I've done this a few years ago but can't remember which side so I picked up the gaskets when RockAuto had them on clearance.
I checked torque a few weeks ago so it's not due to loose bolts.
I'm wondering if it's okay to add a thin coating of RTV to the metal shim/gasket. I'm thinking I must have a slight imperfection that eventually allows it to leak.
Thoughts?
Thoughts?
Go ahead. I run a thin layer of permatex aircraft gasket sealer with the metal gasket. RTV would work just as well.I'm wondering if it's okay to add a thin coating of RTV to the metal shim/gasket.
I tried a light skim of Right Stuff and blue loctite on the bolts. We'll see how that goes.
I also did this today (sorry @Kay86K5 )
I had to add 2" of spacer. Luckily we had a drop piece of 2"x5" rectangle tube at the shop that was the perfect size. It was really cool of @1977k5 to include new hardware when he sold me the kit.
I just have it set to fill each side separately with a Schrader valve.
I was surprised how much just 20lbs lifted the truck. I have them set at 8psi; directions say 5psi minimum. Couldn't tell any difference in the ride with them at 8, which I think is good.
Tomorrow we're going to haul the go kart up to the woods for some riding. Should be a good trial run with the bags.
. Looks good on there. Do you have a part number or anything as to where I can buy that? I know you bought it from @1977 but maybe the box had it on there?Yay! No more saggy ass! Is that a squarebody specific kit?
