We've got too many sign projects in the shop right now. It's a catch 22, because I hope we stay this busy but then I can't take up any shop space for personal projects.
On another note, I think I have a fuel issue. I've been noticing for a while now that fuel pressure seems to be running low. I have a vacuum referenced regulator set for 43psi that I just set last week. However it never gets above 35 to 38 psi even on hard acceleration.
Last week I replaced the fuel filter thinking it might be causing a restriction. After that, I also reset the regulator to 43psi. Still runs under under 38psi even with hard acceleration.
I can't tell there's an issue based on engine operation. It seems to run fine.
I figured the pressure should hit the 43psi setpoint under hard acceleration, but maybe I have that wrong. The system used to hold 58psi steady for the Sniper. Only change was adding the external regulator along with a different efi/engine.
I was thinking a test would be pulling the vacuum reference and see what the fuel pressure does without it. If it can't hold 43psi under acceleration then the fuel system is unable to keep up. If it does hold 43psi then either there's something wrong with the regulator or it just doesn't need 43psi.
Picture below of the regulator. It's in the return line so the connection on the right is fuel in from the return off the fuel rail. The bottom line goes to the tank. On the left side is the fuel pressure sender.
