My sliders have been in need of revamp for some time. I've had to half cut them off to bend them down and reweld them once already, and it was time to do so again.
The primary reason for this is that I couldn't weld much of the back side due to having saddle tanks when the sliders were originally installed. I figured now that those tanks are gone, I should redo the sliders.
My first thought was I should make the cab sliders line up with the bed sliders. However, I realized that would be a LOT of fabrication and complicated. It occurred to me I could kick up the back section of the sliders. This also ended up saving me from having to buy more steel because I could make each slider in 2 pieces. I used a level to get my angle and cut line.
Those are NOT my oil stains on the cardboard, that's from the F550 bucket truck.
Anyway, the best part was the cut wasn't going to be in the door structure at all.
I decided on 2x6 rectangle tube because it would get me a little more tube under the cab for better anchoring of the back side. I went with 1/4" wall since they are so wide and the truck is heavy. The new sliders are only about 18 pounds heavier per side. The bed has 2x5 sliders, but like I mentioned, I wanted more slider under the cab. Plus if I ever do a cage, the wider tube will be easier to tie into.
Initial mockup above, the final installation has the slider tighter to the doors. Below is how my kick up ended up compared to the bed.
You can also see above my big challenge or the part that is going to be the most work. I have a lot of gaps to fill. I'm using 1/8" flat strap to do it. It actually works better because it's quite difficult to weld sheet metal to 1/4" thick steel. The 1/8" thick strap does a nice job of sitting in the middle.
This time I plated the back side of the sliders into the cab supports, I didn't do that before.
Now I just have a lot of welding to do filling in the gaps between the body and the sliders. Also still have the passenger side to do.
Here's a comparison of before and after. I guess the picture is actually after and before.
If you look at the first 6" of the front door, you can see where I had to hack the bottom of the door to clear the old slider the first time it was bent up.
@ktmoutfront might remember I had to borrow a cutoff wheel at the Chinaman Gulch trail head to cut that slot to be able to open and close the door.
