That's what I've decided to do.Run a high volume oil pump.
Martin
The covers are painted and the letters will be unpainted, essentially a brushed aluminum finish
I don't know what that means.FIFY. Lol jk
LOLFarted in front of you???I don't know what that means.LOL
I was planning to pull the timing chain cover just to make sure it looks good. Even before pulling the intake I was pretty sure the motor had been redone but I figure the question then is how good of a job was done on it. So I figured I would double check what I could. Plus I have to replace the harmonic balancer because somewhere along the line the current unit had the threaded holes for the pulley bolt's heli-coiled - poorly. All three bolts were jacked up when I pulled them out.I'd be very happy with how clean that is.
Cam looks fine as well.
I assume you're going to change the main seals? I would probably pop the timing cover off and make sure the timing chain is in good shape. Should be fine but now's the time to take a quick peak at it.
