I also worked on getting some coolers installed.
In the General I had a large trans cooler, 11"x11". With that big cooler, I never saw temps over 170° except for a few occasions like a long hard climb. I had decided to try a smaller cooler in the crew cab. I figured the larger cooler was a little overkill and it would help with airflow through the radiator.
I have a fan mounted on the cooler that runs off a temperature switch mounted on the cooler inlet.
IIRC, this is an 8"x11" cooler.
I found out I had the cooler mounted incorrectly in the General. I had the fittings pointing down, but that's the one way you are not supposed to mount the cooler. The fittings should be to the side or pointing up. Good thing I read the directions.
I pulled the trans shifter out of the General. I plan to make a new, but for now it will get the job done. I mounted the trans temp gauge with the shifter as well.
There is a switch for the torque converter clutch on the console. I also have a button for ignition that I used in the General but it's not hooked up now. I threw the little fuse block on there so I had power for the gauge and torque converter lockup. Down the road it will run the CB too. I'm using a tap off the factory fuse block to power it through an in-line fuse. Down the road when I add the CB I'll probably set it up with a relay instead.
So I found that maybe I need to keep the bigger trans cooler. The trans temp was running about 190° to 200°F. And that was just normal highway cruising. I found this chart on TCI's website that is good reference:
I went ahead and installed the 11"x11" cooler. It worked best with the fan behind the cooler.
And I moved the smaller cooler over and plumbed it in as an engine oil cooler.
