I replaced the crossbar between the front shock hoops. I had trouble with it hitting the temperature switch for the fans and breaking the switch. Notched the crossbar to fix that and then realized a couple of weeks ago that it had also hit the ESC. Broke the mounting tab for the ESC but luckily didn't ruin it.
So I made a new one that would clear both the temp switch and the ESC.
The mounting tab for the power steering reservoir ended up angled a little but not as bad as it looks in the picture.
The catch to all this was that the air cleaner needed to be raised about an inch to clear the cross bar. The easy answer would be to put a spacer in but I have a power charger/salad bowl below the air cleaner. The spacer would defeat the purpose of having that.
I realized the power charger sits in a recessed area of the air cleaner base and if I made the base flat bottom, I could gain my inch. In the picture below the area between the blue lines is where the bottom needs to span to be flat. The area between the green lines is the recess where the power charger sits.
I have mentioned before our business uses aluminum a lot so I'm fortunate to have lots of drop (left over) pieces to use for side projects. I took some measurements and cut a ring out of 3/16" aluminum plate with the CNC router.
I also decided to cut out the center of the air cleaner base to match the top diameter of the power charger.
You will notice in the picture above I have sanded the outer perimeter of the housing. I also sanded the aluminum ring.
This is in preparation to "chemically weld" the 2 pieces together. We've been using this very strong glue for over a decade now to glue aluminum panels to steel and aluminum frames.
It is a 2 part product kinda like JB weld but it flows like caulk. The nozzle has blue baffles that ensure the proper mixing of the 2 parts. Here's the glued together base:
You will notice a ring recessed in the center, that is for the power charger to sit into and keep the air cleaner properly centered over the throttle body.
Then I painted it all black.
The last thing needed was to make the stud longer. Since it has a bend in it, you can't just get a longer stud. The threads that go into the throttle body are 1/4-20. I cut the head off a 1.5" bolt and used a union nut to join it with the air cleaner stud.
Could have made the add-on stud shorter. It bottomed out in the throttle body before getting to the union nut and I have plenty of stud sticking out of the air cleaner lid.
Here's how it sits on the throttle body.
You can see the ESC is kinda angled up and the wires are smashed down. I'm lucky one of the wires wasn't ruined.
