I was hoping it was a silver nugget.
So in discussing thoughts on whether or not I should get a new oil pan, I was looking at oil pumps. I'm wondering if I should put in a new high-volume/hi-pressure in the motor while I have it apart?
Unfortunately the oil pressure gauge didn't work in the donor truck so I don't know what the oil pressure was before pulling the motor.
Is 1800RPM on the drill the same as 1800RPM if the engine is running? I would need to find a gauge. Be cool if I could find on to thread straight in the port that had the factory sender.Drop a guage in the block and prime it with a drill...
Yeah a dewalt drill can hit the pressure limitIs 1800RPM on the drill the same as 1800RPM if the engine is running? I would need to find a gauge. Be cool if I could find on to thread straight in the port that had the factory sender.
Going with wives tail on that one
