x2 only style i run on my trucks .I thought all 85+ trucks had the overflow canister on the pass side fender well (my 91 K5 is like this)? If not and you want to change, I got my canister from the dealer for under $40 last year.
I removed it. I didn't like it just hanging out over there sticking out like a sore thumb. I have other stuff on that fender now; battery distribution block and ARB manifold primarily.I thought all 85+ trucks had the overflow canister on the pass side fender well (my 91 K5 is like this)? If not and you want to change, I got my canister from the dealer for under $40 last year.
Spectra didn't have another one in stock so this one is a Mishimoto. I have also read the same about Spectra's packaging. I was hoping Mishi would be better. I've received a Jegs radiator and a Griffin radiator in the past without any issues, can't figure out why the radiator manufacturers can't figure out a good way to pack their own product.
I'm going to see if Summit can make a fuss and get them to improve the packaging.
No radiator for me.
This one is all smashed in on the bottom. I'm glad Summit is so quick to take care of me, but I would like to receive a functional radiator at some point.
5th times the charm.You have the same luck with radiators as @Babaganoosh has with trannies!
It's Shawn rubbing off on you.5th times the charm.
Most likely, he hasn't seen the truck in a long time, both of us have been way to busy.It's Shawn rubbing off on you.
