Anyone know if the flange for the sye NP241 will fit the NP205 rear output?
You ain’t gonna make it far!I'd bet Mark's money
Since I have a newer NP205 (1980) with the front output flange, that should be the same bolt pattern as my NP241, correct? I thought I remembered all the front output flanges are the same and that any front shaft from an 80's tcase with rear slip yoke uses the same driveshafts.
I sell t cases without flanges all the timeDid a Google search and Denny's seems to indicate they are the same.http://www.dennysdriveshaft.com/p15...1_1_transfer_case_yoke_1410_series_fits_.html
Trick is I would still need something in my NP241 so I can sell it. So I'm not sure if it really gains me anything.
Depends on if the driveline brake goes with it too. Which would also mean I need to keep the flange with the case.What are you trying to get out of that 241?
($$$ wise)
Normally I would buy from them but I have a Tom Woods certificate. Although I may need to see what needs to happen with the front drive shaft before using it.Yeah, I wouldn't think it would be a problem...depending on who buys it might need/want to swap out the flange anyways (they might need a yoke instead of a flange). So pulling the flange off to put on your 205 so the outputs are good to go I think wouldn't be a bad move.
Either way, ORD sells flanges for pretty cheap:
http://offroaddesign.com/catalog/Transfer Case Yokes.htm
I bought two of their flanges for my Titan/205 combo cause I was kinda the same as you that I wanted to keep my SYE 241 completely intact...but not to sell...to put in something else down the road. I even kept the full cable shifter with the 241 so it's a full package and easy to swap into another square at some time (I'm sure I'll have another one some day that it will go into, haha)
It's a weird color. I think it's supposed to be a metallic gray but it picks up a hint of purple. Maybe there's purple flake in it.Oh nice.
El berenjena
Yes. This will be for the boys to drive.It looks 2wd
I had to look up your Spanish.Looks like eggplant![]()
