I did spend all the money, just not on upgrading. I spend all the money all the time so I have no money.Sure it was. Spend all the monies at once is what you told me
If I'm going to hang the tank with the straps under it, the crossmembers the straps bolt to would be just under the top flange of the frame based on the length of the straps. But I would need some sort of bridge over the tank to tighten the straps against I think.Based on how the frame is and it’s location, you’d have to build a “bridge” to hang it
At the very least there will be an access panel of some kind for the sending unit.Are you going to build the bed to be able to access the tank from above? If so I'd do the crossmembers below it and make it removable from the top side.
Yes. Getting tank setup first to get the saddle tanks out of the way.Are you not going to shorten the wheelbase as you’re going through this whole process?
Past the shackle flip brackets there will only be enough overhang for rear bumper brackets.I meant to replace the saddle tanks with a transfer tank in the bed. An L shaped one designed to be used with a tool box. If you are altering the wheelbase or frame, why leave the long overhang behind the axle?
Martin
Kinda depends on how the bed lays out with storage compartments. Basically I'll run the filler hose over from the tank to the bed side, but it might have to zig zag around something. At least that's the plan for now. I can see it changing as things progress.Do you plan on using the stock filler location?
The only thing I'm not liking about this plan is the receiver hitch is going to be at least 2-1/4" higher than it is now unless I make some hellacious drop bumper which I'm not thrilled about. I'm already running a 12" drop for the camper.Past the shackle flip brackets there will only be enough overhang for rear bumper brackets.
I spent most of yesterday figuring out where things are going to land. You can see some of my hen scratching on the frame. Added blue marks for more direct translation.
This will shorten the wheel base 25" which will put it about 9" longer than a long bed regular cab pickup or suburban. Then cut nearly 30" off the end of the frame which will end up making the overall length of the truck about 4" shorter than the bumper to bumper on my C10 longbed.
I'll be paying attention, I have wondered if this would be a good spot for a tank.Kinda depends on how the bed lays out with storage compartments. Basically I'll run the filler hose over from the tank to the bed side, but it might have to zig zag around something. At least that's the plan for now. I can see it changing as things progress.
I've been wanting to build a bed for quite a while now. Originally I was going to keep the wheel base the same so I had more bed space, but now that I have the C10 I don't need the bed in the crew cab as much. The saddle tanks have gotten so beat up I have no idea how much fuel I have in them except for right after I fill them. After the Steel Bender exit last year, I can only use about 13 gallons of the driver side tank. Plus after bending up the slider on the driver side, I've really been wanting to be able to brace those up better but the saddle tanks are in the way.Wow. Major changes. Should be a new learning curve driving off road.
Only suggestion I could add is to reinforce the frame behind the cab where your front spring hanger is going to land. That's exactly where Larry's frame cracked last year. Between the wheeling and towing that area is going to be stressed to the max. (It is on any truck for that matter) On a spaghetti frame squarebody it's best to beef it up now while you move stuff around so you can incorporate the added structure into your mounts.
The problem with putting it there with the factory setup is the brace I was mentioning above. There wouldn't be enough room between it and the front of the bed. You could cut the bed floor and underbracing out and drop the tank in about 3", but the rest of it would be above the bed floor. You might be able to get a smaller tank in there, like the ones LMC sells to convert pickups to under bed tanks. Those are only 20 or 25 gallon tanks and they don't look to be as long as the 31gal K5 tanks.I'll be paying attention, I have wondered if this would be a good spot for a tank.
