I actually would like to do that for the reason you mentioned. I have to convince Nicole tho; she thinks it would be too poser looking because I'm not fording deep rivers.
Listen to your wife, she's correct.
I was thinking something like this truck.Ooooooh...military-esque fake oil bath air intake like the old deuce and a halfs had on the fender...
Actually a scoop of some sort might not be too bad.You need one of those VW baja bug oil cooler scoops, sticking out of the side of the fender.
The other good point she has is it will get beat to hell on the trees around here.Listen to your wife, she's correct.
Besides fording the Nile river associated tributaries in Africa, the other benefit of a snorkel that is high up is less dust intake versus a lower intake. At least that's what the khaki and pith helmet overland types like to tell themselves over blended whiskey drinks around the campfire that the hired help set up for them.I actually would like to do that for the reason you mentioned. I have to convince Nicole tho; she thinks it would be too poser looking because I'm not fording deep rivers. I've also debated about putting a hole in the fender and just putting a "hat" on it.
Probably need to find a pie tin or something I could mock up and see if it will work with the hood.Besides fording the Nile river associated tributaries in Africa, the other benefit of a snorkel that is high up is less dust intake versus a lower intake. At least that's what the khaki and pith helmet overland types like to tell themselves over blended whiskey drinks around the campfire that the hired help set up for them.
Honestly I've not seen one on a square that looks "right" to me.
I do like the idea of a h1 style short stack poking up out of the cowl at the base of the window. Done right could be pretty cool.
That's how Nate did his. But his truck is just loud so it's hard to tell how much it contributes.Cut a hole in the firewall and draw air from the cab.
I'm kidding.
Kinda.
Good idea on the lights, that should help narrow it down.Switch the left and right blinker housings temporarily and see what happens. Rules out the blinker.
Is the fuel gauge matched to the sending unit? Take the sending unit out, ground it and run the float up while watching the gauge.
The change to the filler neck didn't help. Matter of fact it's worse, can't even get fuel to go in at all. Probably gonna have to do something like @skunked between the tool box and spare tire.
The other frustration is the fuel level still isn't reading right after running a new wire from the sender to the gauge. I unbolted the filler neck from the door so I could hold it up above the tank to fill. I filled it until gas came out the filler. Gauge is reading 20 gallons. I have a 40 gallon tank.
Last time I put gas in it I was pretty sure it was full. Today I put in 10 gallons which makes sense for the number of miles driven since the last fill up.
Does anyone know if the 40 gallon tanks use the same 0-90ohm on the sender?
I'm also having a problem with the turn signals. If the headlights are on, the right indicator on the dash is on constant. If I try to use the right signal, it flashes kinda erratic. Left turn works fine.
When the headlights are off and I put the right turn signal on, all of the indicators flash like hazards. Again the left works fine.
I have LED flasher modules so it's not that. It could be the way I wired the LED lights into the harness. Or the right LED light is messed up with its on board wiring. Any ideas?
