I got too distracted looking at old wheeling trips and friends.The Cherry Bomb
This thread is for the general discussion of the Item The Cherry Bomb. Please add to the discussion here.ck5.com
Page 1 of my build thread shows how I did it.
I looked at his as well and started seeing some guys.I got too distracted looking at old wheeling trips and friends.
Did some measuring and I think it's mostly due to the bed being about 1/2" lower on the one side. I kinda remember noticing that when I originally built the bed. Luckily the spare tire kinda breaks up the horizontal plane so it's not obvious.
You don't run a pinion guard?I'm trying a little experiment. Since the only transmission cooling I have is the remote cooler in the bed, I thought it would be interesting to try a frame rail cooler to see what effect it has. I'm curious what a little passive cooling might do since I have none now that the cooler isn't in front of the radiator. Since I needed to fix the fitting that failed last month, I figured it was a good time to try something.
This is a little 24" dual pass cooler. I thought it would work well for being able to keep it clean with a quick hose down. It was only $45 so I thought it was worth testing out.
You know, it's funny, I never noticed it before, but several guys at FSI last week were running full driveshaft sliders. It looked like a belly pan attached just under the pinion and (presumably) to a crossmember up by the transfer case.No, I don't have a dirt shovel.
set it up the same as a ORD or DIY4X style anti wrap bar it would work good .You know, it's funny, I never noticed it before, but several guys at FSI last week were running full driveshaft sliders. It looked like a belly pan attached just under the pinion and (presumably) to a crossmember up by the transfer case.
As long as it could move freely, It probably would work pretty good for long wheelbase trucks.
This Scott guy is crazy!You don't run a pinion guard?
