Big91RustyBucket
desertrat67 said:I understand wanting to just put things together. Sometimes you just want it together just to see it together.
Yeah It happen's.
I've been pretty busy lately, but I might take you up on that sometime later. I actually have a rig, but I've deemed it to rusty to be worth it, so its getting sold and I'm gonna find something betterBig91RustyBucket said:Shoot beecher is pretty close. You should come wrench sometime. You got a rig?
black rust said:I'd personally go with the d60/d70 to do something different. d60/14bff seems overdone to me
Stupid question: was there ever a d70 front?
Like has been said before, If ya want to run deeper than 5.38s go with the 60/70 otherwise, 60/14bff. Wait a sec, your going to install a fordhp 60 right? I think 5.13s are the lowest gear you can get for those.black rust said:I'd personally go with the d60/d70 to do something different. d60/14bff seems overdone to me
yea, I forgot the new dodge 60s are driver's side drop. So it will still work with your np231Big91RustyBucket said:It will most likely be LP 60. As it is availible inexpensively.Unless I score an Hp real cheap.
black rust said:Ok, so never mind on the d70 front.
black rust said:Yeah, saw that too. Something like a 11.25 inch ring gear? Seems like the bigger size isn't anywhere near worth the increase in strength
AJMBLAZER said:Which goes first...the complicated itsy bitsy front end or the rear end?
