That thing is cavernous! Those benches are like couches too. Sweet road trip mobile!
I think that's the same master cyl I'm running and I love how my brakes feel and work. What's the reason for the line adapters? Mine bolted up just fine, Did you swap them front to back or something? Do you front brakes lockup before the rears in a panic stop? I was going to install a manual adjustable prop valve to turn down my rear brakes but I may just swap the lines if possible cuz that would be lots easier.After a freeway trip and some more in town driving, all is working well still. Rolls straight and quiet. I just retorqued the u-bolts today. They relaxed and everything settled in and they were about 20 ft lbs loose. Now I need to get these tires off road! I hope the rain allows a trip next weekend. Anyway, here are a couple of pics of things I don't think I mentioned yet.
Top left is the final shot of the angled spring perch and counter-angled ez-inch. Bottom left is the conversion u-joint needed for this axle swap. Luckily, (I guess), a transmission shop ruined my stock driveshaft so they had one made with 1350 flanges. The aam has a 1410 yoke. This u-joint by neapco (pn: 2-1435) marries those two. You might notice the u-bolts I thought I could use. The threads in the yoke were so caked I thought it was straight all the way through. Maybe one day I'll mod it to work. Until then, the old strap n bolts went in. The right is the brake line T I used. I bent the bracket so it pointed the T in the right direction. It is actually the aam line. It is longer than the one that came with my lift. That pic is with the axle fully drooped. You can also see the lines I made to get the T to the passenger side and one of the flares on the aam was cracked anyway. Also, the vent tube is much smaller on the aam. I went ghetto fab and cut a short piece of the aam hose and jammed it up the old breather hose, lol. It's super tight!
Here is the hydroboost, master cylinder, and brake pedal rod. Don't mind the wires and zip ties, I'm still cleaning up. You can also see how I tapped the return line. It's tapped after the cooler, and the perpendicular hose is from the booster. This was the recommended way. Hydroboost pedals have a larger stud for the rod eye. Little did I know, within hydroboost studs, the 94 hydroboost eye was too loose for the 70s pedal. Luckily I hung onto the 70s eye. I threaded it and lock tited the coupler nut to it. I had to thread it so I could change the seals on the pedal piston without removing the rod from the pedal piston thing (which is a pain). I can also now service the unit without removing the whole thing from the firewall, and have slight brake pedal height adjustment.
Next up: clean up wires, wheel spacers, some corrosion control, refinishing the wheels, fix upper shock mounts, and parking brake solution.
I've been planning a rear bumper. The main reason is for a rear tire carrier since I have a full size spare now. I'm posting today to share my idea and get some input. I want the base to be a 2x6x1/4 rectangle tube as the main piece, with 1" thick recovery points that pass through to mount to the frame, with some other minor details that aren't yet important. My spare will be mounted on the driver's side to allow visibility on the passenger side. I'm entertaining the idea of a fold down carrier and here's where I want to bounce ideas off of you.
I was thinking of getting four of these bushing/dom tubes and some weld on tabs:
I would weld two pairs of tabs as far down as possible on the lower face of the 2x6, maybe 12-15" apart, and the other two pairs near the top of the bumper face so they are a few inches over the lower ones. The tire support frame will be round tube, with the bushed doms welded in so the tire support swings down on the lower bushed doms and the upper bushings will have pins that are removed to allow it to swing down. The tire support frame will also go outside of the tire (like most swing downs) to allow the tire to rest nearer the body. My loose estimations will have the tire resting on the ground at a 30 degree angle or so.
Know what I'm getting at or will a sketch help?
I have more details worked out, and reasons for the design, but my hope was to get opinions on any shortcomings of my proposed idea about the swing down portion. It seems like it'll be plenty strong to support the tire and frame in this configuration, but I also see that the pivot point and security point are very close together which puts more stress on the mounts. The leverage combined with the bushings might cause too much movement too. What say you?
Kert's design certainly planted the seed of a swing down option! However, I want mine to be off to the side (I want barn doors in the future, and I want to be able to open the passenger side without moving a tire), and my mounts/pivots will be external. I have an idea for an assist, but it's not like the DIY4x at all.
Hope you got a big bag of popcorn. Wife, dogs, and I are livin on a lower enlisted gubment income...but I do have a few things to sell![]()
Mine's kinda like that, except centered, and holds a bloody heavy Toyo 37". I ended up putting horizontal reinforcements at the body crease (i.e. right above the tail lights). Coupla pix:
Each wing holds a jerry can, but also latches onto the center tire holder. They then swing out to let the tailgate drop.
Note that with that 37x13.50, the center section is just slightly over what one guy can comfortably lift off the ground. I end up either using a helper (easy with two guys) or winching it when solo (as seen in the first pic.) YMMV depending on your tire, back strength, and that angle at the bottom. Do put the bottom hinge point as low as you can go to keep that angle minimized (ie closer to horizontal.)
Other thoughts: do a mockup first with cardboard, but I suspect you'll find you can block a lot more of your rearview than you think. Also, if you're going to attach to the body, do it as high up as you can (gets more leverage), and sandwich the metal for strength. Umm, see
That's flat stock, bent with a sledge to match to body curve. Thick one on the inside, drill and tapped, then thinner one outside with holes through, then finally chunks booger welded around the circumference for further reinforcement.
And if you think of any clever lift assist/spring arrangement, do a good writeup so I can steal it
-- A
?! At 36, sometimes I wake up and move something wrong and I'm like
...and that's why I want that assist.Like to see the lift assist you do.
Didn't notice it but do you have part numbers or sizes on the adapters you used? I have the same master with my lines hooked up like normal and my rear locks up first and wants to pass the front in the snow . I was gonna try to swap the lines on the master and see what happens before I go splicing in an adjustable prop valve.
