Wanted 90 K5 fuel pump/sending unit
ACTIONKING12
Registered Member
Atascadero
I need the fuel sending unit. On a ‘90 it includes the fuel pump.. I’ve had no luck finding a brand new one.
If anyone has a used one. or link to a web site I can find what I need that would be much appreciated! 12-16 psi!
Doesn’t mention anything about psi. I’ve got a Carbureted 350 SM
When you spec an in tank fuel pump for a 88-91 squarebody, it’s going to be 12-15 psi for the stock tbi injection. If you swapped to a carb, you’re going to need a return style regular to knock it down to around 6 psi.
