scottsdale86
That engine will make that power level easily with the heads cleaned up and a cam change but the problem will be TBI. Its an outdated system and burning chips for them is expensive and has limited adjustabilty. You may be better served with an aftermarket EFI system. More adjustabilty and versatility but you are stuck with that makers parts whereas a stock TBI system is everywhere. If it were me I would do a nice flowing valve job, roller rockers, good oil pan and do a real good set of headers and free flowing exhaust from the heads back. Probably put you over 350 ft-lbs easily and run very well.
Now i have built a few big blocks now and can say that carbed these engines are very forgiving. With exception of their weight are perfect for off roading because the torque is just right where you need it and it doesnt have to work hard at all. Another option is a good dual plane manifold and a SMI or JET quadrajet tuned to your needs with a nice idling cam and good head porting woud really wake that engine up. Also what port heads are on it now? Everybody $hits on oval port heads but i think they are just ticket for most off roaders needs.
