Got the skid plate, and fuel tank dropped today. Quite the beating by yourself. Got the fuel pump out, going to replace it with a walbro 255.
From what I can tell the stock 3/8" line is large enough. I have read elsewhere that you 600 hp is at the upper end of what a -6 AN line can support which is 3/8" ID. The hard lines are 3/8" OD. A mechanic I have been consulting says he has made 700-1000 hp cars with -6, and thinks I am good. I am going with that for now, bc replacing the lines is very expensive (all of this is expensive, but braided lines seem unneccessarily so) and a PIA.
Going to start doing some rust repair and painting while I'm waiting on the pump. Ryoken has a thread on rust that I'll have to check out.
Questions
Are the stock fuel tanks worth saving or should you just replace with an aftermarket while you have it down? The reason I ask is because it seems like I cannot get all of the fuel out, which means I cannot get all of the junk out either. I have done dumb **** before, is there any trick to getting the gas out? Obviously I have tried flipping it over and at several angles.
