It all boils down to surface area. You could use one of the square,flat air bag/bladder things like they sell for making a gap between a window and a door.
The are used to get a tool in to unlock a door when you lock your keys in.
Then put a piece of plywood or something with a lot of surface area on the good side, and a piece of plywood with a small wooden block on the other side.
Put the plywood side against the bladder, and the small block against the dent. This concentrates all the force on the dent on that side, and spreads out the force on the good side.
Plus keeps the small block from punching a hole in the bladder.
Neither the key nor the cab-switch could be heard when you used them. Then, randomly, I was able to get the window to go up half-way, to where it normally gets stuck. Typically, I get out, bump the window with my hand, and then it'll go up the rest of the way. But, when I hit the switch again, it did nothing. Thankfully, after enough bumping on the cab switch, I was able to get it to go up. Down works with both key and switch all the time. Not really sure where to begin in terms of fixing this.
