Hopefully he's using those new Reid super 60 knuckles
Supposed to be portal boxes. Not sure if those still use a normal steering knuckle or if the knuckle is integrated into the portal box.
Original plan was to use Dana 80s front and rear with portal boxes but obviously he is starting with some normal tons. Maybe there wasn't an easy way to run the portal boxes on Dana 80s? Think it would be even cooler on a set of axles that weren't so common nowadays but I digress. Either way it is going to be nuts with portal boxes and 46s
