Man, you guys with your suggestions are the best! Just a min and I’ll post my wife’s phone number so you can tell her….
Oh hell No !Man, you guys with your suggestions are the best! Just a min and I’ll post my wife’s phone number so you can tell her….
All you need is a couple of $2 jugs of distilled water with the concentrated coolantI worked in parts for a long time and, while I’m sure it’s ideal, using something other than tap water was never discussed ••but•• I’m seeing that mentioned more and more lately. I guess when I do the final refill with coolant I’ll take out a loan and use 5 or 6 of those premix formula jugs.
Oh hell No !
She partly blames me for a lot of what has been spent on your truck already - I’ve seen her upset and very happy and I’m stay’n on the happy side.
That being said she is a forgiving person so if ya’ buy a DART block and head combo I’m sure you would only be sleeping in the shop for a week or so.
I’m so proud of you - that’s how you are supposed to think!I just don’t think the block and heads would be worth it without a 1/4” crank.
We need proof of this kid thing.Tap water with minerals has always been a no go. From when I was a kid 55 years ago. (man I am old) The minerals cause electrolysis and the rust starts. You could change out to an all aluminum BBC and not need to worry about it anymore.![]()
I have a lot of scars from then.We need proof of this kid thing.
I saw that coming so I went another way.Well, that backfired. I was hoping to get you stirred up over the 1/4” crank I turned down.![]()
But since you brought it up all the other brothers need to know that your machinist offered to trade you a full BBC 1/4” stroke rotating assembly for your new outta the GM box LS-7 cross-drilled steel crank - as cool and great of a piece that crank is the stroker assembly giving you 496 inches would have been so much better.
I forgot that I’m still mad at you over that and am not talk’n to you…
No replacement for displacement.mo cubes is mo betta!
That’s what they say…but ets prove otherwise.No replacement for displacement.
Ohhhhh PREACH IT !!!Doesn't have to, a stroker crank picks up everywhere, if everything else remains equal.
Now, if you are some displacement limited class, then RPM is your game and you want a big piston so you can have big valves for high airflow for high RPM, in which case stroke goes down with a larger bore and a limited displacement.
Or maybe if you have super high boost, you can't make the piston too short or it won't take the boost, stroke is limited by deck height.
But most else, mo cubes is mo betta!![]()
AMEN to all of that !Yes it gets exponentially expensive, RPM, boost, and not just the power, all the drivetrain parts to take it, and you can't skimp on the safety gear. Plus once you have all that the routine maintenance gets out of control.
Now a stroker crank on the other hand, that adds all the torques and horsey powers, with no extra maintenance. I use one pretty much every build for my own stuff.
If I am buying a crankshaft, I get the biggest one I can reliably fit in the block I have, no reason to buy one smaller.
