Here are pics of my firewall and glove box.
Now I need new battery cables for the truck and winch.
By the way, tell me you at least hooked up the + cable of your battery after the pic?![]()
My daughter took that pic while I was reinstalling the battery. Still gotta go have new cables made, the winch cables are way too short and the engine cables need to change as well.
I was about to do some stuff with the Dodge (level it, rear air bags and bigger tires) but I may need to redirect that money towards the K5 motor. We'll see...
. swapped it out now its all better; hope you dont have to go that far
Just a frustration update...
#2) This is the second motor the roller rockers have been on and they are showing wear. Looks like it'll always have some chatter until I replace them (kinda sounds like an injector click).
#3) The truck has no power, this is a 454 w/ 5.86 gears it should feel a little peppy even if it's not a wild motor. To get it where it starts and runs decent the timing mark is way off the scale, it appears the balancer may have slipped (it also wobbles a little). I have a new balancer on the shelf so I'll be swapping it on soon.
#4) It still has a noise deeper in somewhere. Maybe a light wrist pin tap. great.
CRN-10307
Brand: Crane Cams
Product Line: Crane Energizer Camshafts
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: 2,200-5,600 RPM
Intake Duration at 050 inch Lift: 226
Exhaust Duration at 050 inch Lift: 226
Duration at 050 inch Lift: 226 int./226 exh.
Advertised Intake Duration: 282
Advertised Exhaust Duration: 282
Advertised Duration: 282 int./282 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.533 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.533 in.
Valve Lift with Factory Rocker Arm Ratio: 0.533 int./0.533 exh. lift
Lobe Separation (degrees): 108
