That sucks, E's should handle the weight fine if they're aired up correctly.
What size wheel?Dollar per mile winner is the Yokohama geolander ht. I've recommend them a few times here. I'd run them bald before a failure. Probably always at max or overloaded. We would break spindles off and the tires would be ok running three for a couple hundred miles back home.
I’m going to follow your lead on that if the 85 will fit under my fenders.235/85r16 load range e. It's an lt tire, not st. It handles the scrubbing much better than a trailer tire because its engineered to be a steer tire and load bearing tire simultaneously.
So what’s on the to do list next? Don’t start slacking now!![]()
I forgot.... sanding, lots and lots of sanding. All that bare tube is orange now.![]()
Welcome to my world![]()
I always spray a ton of wd40 all over the tube when I get it. It also helps getting it off the floor. I only had one tube that had just a tiny amount of rust on it.
