'91 Suburban. Slowww Build
Rig is looking good. Just curious, though. Why would you want to build a "slowww" suburban?
Rocket boosters are on back order at Amazon. I'll definitely post pics when installed. I'm a little concerned about the numerous oil leaks causing a fire, more research needed
Harnessing those leaks into the burners should help your efficiency numbers
That's genius. I was prepared to waste a combustible fuel source. That is why this forum is so great. Lol. Thanks for the kind words. Next on list is new exhaust. Truck has a very small and very loud muffler exiting through 2 giant chrome tips. Any ideas on a quiet muffler with good flow are appreciated
Dynomax super turbo is not bad. A balance pipe is the best for quieting it down
Couple of updates to report. Ended up getting a Flowmaster 70 series muffler. Really helped with the drone inside. All I can hear now is the radio and tire hum. I ended up getting a new steering shaft from JCWhitney for a 1993 Jeep Cherokee. Install was pretty straight forward. There are several write ups floating around. And most important, a ck5 sticker that added enough horsepower to blow out my radiator. Also replaced that today.
URL=http://s626.photobucket.com/user/rmy697k/media/image_zpsqy7oa7q6.jpeg.html]
[/URL]
I found a 10 percent coupon online. Shaft was around 104 to my door. It's new. Crown Automotive is the supplier.
