michael0584
There's so much airflow when on the freeway that there would be no difference, may effect the AC at idle, but cooling should not be effected.
I have a white 1991 V1500 Sub 1/2 ton, wish it was a 3/4 ton. I have the duel factory shocks up front, wonder if it was an option? Mine has the dreaded paint issue though, would love to get it painted. Second owner with all the service records. M4
Yep, option. Cool that you have the window sticker.Windows sticker shows quad front shocks $100.
Nice Suburban, it's an inspiration how clean it is (at least compared to mine).
Hey on that super cooler you installed, I see that it takes 1/2 NPT fittings. I was wondering if the internal tube size got narrower inside or does it have 1/2 tubing through out?
As I do some reading on the subject it seems that a larger diameter tube can cause a pressure drop.
After frying a trans I'm going to add a second cooler after the radiator. I want to do the lines in all steel so I'll need to find someone that sells 1/2 NPT to whatever the normal trans lines are, 3/8 farrel fittings?
No idea. Scott (4x4high) recommended this cooler, as it matches the drivers side oil cooler exactly. I took his word for it, and didn't question any of the details. Lets see if he chimes in....
As for lines, where the stock lines tie into the radiator they are 5/16" flare (tube) fittings. What the end that ties into the trans is, i don't know. I didn't want to cut my factory hard lines, cause if the aux cooler fails, i can hook it up like stock to get home.
Good point on the factory lines and the aux cooler failure. I'll bend up a piece of tubing and keep it in the burb.
I found the fittings at Napa to make all hard lines.
Also, where did you install you tranny temp gauge sending unit?
The sending unit needs to be tapped into the pan. Mine is not....but should be. Mine is T'd into a cooler line by the trans.....but needs to be moved.
Thanks!
Got a Gentex 177 mirror with auto dim, compass, and temp readout installed, but F'd up my radar detector in the process of trying to hardwire it with my own wiring, so i need to relax a while before i do a writeup![]()
