I wonder if the roof rust is a Dodge thing (like cracked frames on Chevy’s, etc)? I have a love friend with a W250 and his roof is rotted across the top of the windshield too.
It’s very much a dodge thing, they used a stupid 3 piece design in the front by the drip rail….you have the inner roof, then a middle piece and the outer skin. They all come together at the drip rail. Dodge seam sealed it at the factory but over time the seam sealer cracks and moisture finds it’s way into the layers. They also get moisture inside when they sit out in the sun during the day and then it cools at night…couple that with the fact that dodge didn’t paint the insides of the roofs and it’s not a good combo.I wonder if the roof rust is a Dodge thing (like cracked frames on Chevy’s, etc)? I have a love friend with a W250 and his roof is rotted across the top of the windshield too.
I'm not even going to ask
Exactly what I was wonderingI'm not even going to ask
8”? You mean 18” right?Got the new shoes on today, 35x12.50s on some black steel wheels, think I’m gonna bob 8 or so inches off the back of the bed so the ass doesn’t catch every ledge I drop off of
Yep, I had a set of 33s and liked them so I sold them to my neighbor and bought the 35s. I wanted a set of interco SXs they had on the blem list but I waited to long to pull the triggerMilestars?
I suppose that depends on quantity of mind altering beverages consumed during the process8”? You mean 18” right?![]()
Crawled under the truck I was grabbing them from and there hangs a 205, so naturally I had to grab that. Was wheeling it out to the gate and tripped over a 208 that someone pulled to get a transmission and left sitting there….the work was done so I grabbed that too:Round 205 and fixed yoke 208(is that dodge?)Went to the junkyard today to grab a set fuel lines that go from the TB to the frame mounted lines because the PO decided to run rubber lines front to rearCrawled under the truck I was grabbing them from and there hangs a 205, so naturally I had to grab that. Was wheeling it out to the gate and tripped over a 208 that someone pulled to get a transmission and left sitting there….the work was done so I grabbed that too:
Yea that’s one thing I wish Chevy would have doneThat fixed yoke 208 is a WIN!
23 spline dodge 205.Went to the junkyard today to grab a set fuel lines that go from the TB to the frame mounted lines because the PO decided to run rubber lines front to rearCrawled under the truck I was grabbing them from and there hangs a 205, so naturally I had to grab that. Was wheeling it out to the gate and tripped over a 208 that someone pulled to get a transmission and left sitting there….the work was done so I grabbed that too:
Yup23 spline dodge 205.
That and the sleeve that goes between the trans output and the t case input…they treat me pretty good at the local yard but I spend a lot of time there tooJust that shifter bracket is worth more than what my yards are charging for the whole tcases. Well done.
