Buddy of mine got back to me, has the "416" heads on a lower mile 305 with a hatched bottom end. Not HO heads, but close enough. Should be a bit better than the truck heads.
Why couldn't you convert over to a tow-piece gasket setup while you had the pan off?
... if what I'm reading is true...
Intake looks pretty clean. Maybe you can paint the valve covers while you're waiting on the Alberta ****er to bring the gaskets and grommets back.
I'm not familiar with the people of the various provinces of Canada, but I'm starting to wonder if those Abertans are all a bunch of trouble makers.... if what I'm reading is true...
When I went from my 305 to my current 350 this summer, I ended up using one valve cover from the old 305 because I wanted to use the later model air filter or something (I can't remember). So I now have one black valve cover and one orange one. If someone says anything about it, I'll knock 'em out!![]()
I was wondering when you would start bitching about missing parts!
Don't forget about the oil filter adapter!
Looks good Focker!![]()
Now your starting to get it!![]()
Hahaha. I had no idea. Just look at the tire smoke in your avatar. You're all just a bunch of hooligans!![]()
