Well what started out as a simple task, turned into a donfuckaround when it came to do the pass side of the motor. Dropped a nut down a hole into the lifter valley. Went to get it with a magnet, into the pan that went. So off came the pan, prob not the end of the world. Cleaned it out, fired that back in.
After finishing all the valves on that side. Noticed #2 exhaust rocker was quite worn, and was not pumping hardly any oil up top. Not sure if it was the lifter got plugged or what at some point. By chance I was able to fish that lifter out through a hole in the center it the casting. Took the lifter apart and everything looked okay? When I was picking up a flexible magnet at a big box store this morning they had a few lifters in stock. That was more shocking than getting the lifter out at that point.
So I greased it up, and by chance fished it back into place. Replaced the rocker arm with one I got from a buddy. It started pumping oil up, so on went the tins. Ran it for a solid 15 minute breakin tonight.
If I had to guess there prob was nothing wrong with that tappet other than it may have had some crud in it. It was pumped right up when I took it apart on the bench yet. The tip of the rocker was worn in quite a bit, to the point it wouldn’t allow oil to pass through the hole in the rocker.
Not sure if it’s dumb luck I caught that, or that I was able to take of it fairly easily? It didn’t just happen, I’d guess it was like that for quite some time.
I guess time will tell, gonna hopefully get some miles on it this week if the weather stays nice.
