It snowed here yesterday. Today it melted 99% of it.
Martin
Martin
I guess it got corroded just because of all the current going through it maybe. I would say make sure it's tight and use some dielectric grease this time. I've seen loose ground wires corrode like that, but never the wire that you're talking about. That is weird.
Y'all guys kill me with that nice cool weather. It's been 75-80 + degrees F here all week. I've been sweating already and you're posting snow pics! I may have to come up for a visit.
I can't see your pics but it sounds like a mess. I've ran into similar situations before, so I feel for you.
As far as the outer lock rings for the hubs - are you talking about that big round steel ring that goes around the inner diameter of the hub? Lots of guys leave that one out. I don't really even know what it does. I always put it back in, but I don't know if it's necessary.
Hahaha no problem.
If I recall it was the snap rings for the stub shafts that didn't fit.
But I've only had one or two rigs that have had the inner circlip on the stubs Fwiw!
. So I swapped a set of 3/4 turns buddy had Layin in his junk pile. Have to change wheel bearings on one side, they a little toast
. I forgot how well a stock Chebby on 31s is in the mud too
