Aluminum dash
Weight of the two main pieces is 19lbs. Add.... 3-4 lbs. for passenger compartment, say 25 lbs. shipped weight.
4x4high, shipping to, 94538 UPS ground....
$22.00
Now once you get it all figured out if it will fit over everything under an 89 blazer dash that is fully loaded let me know. :thumb:
damn, what a sweet dash. :bow::bow::bow:
How does the dash attach to the truck? Does it bolt to the side panels of the cab like the OE dash?
Yep, it does. There will also be a center support similar to what the factory did.
That's damn nice Kert. I guess I will be sending you more of my money as soon as I get around to doing my dash. I could damn near drive to Iowa to give you a hug. Been needing something nice to replace my dash for a while now. I wont do it though, I like my man card!!!
I like my man card to, we can just shake on it.:D
Very interested. Any idea on how long until they will be available? No heater or anything under dash needs to be there.
Roll Cage
Have you considered integrating a front roll bar with this design. I would be more inclined to go through the effort if there was functionality associated with this rather than mostly looks. This is the perfect opportunity to cover both.
Quite a bit more work to do before they're ready for release. ASAP though.
We have discussed an option for openings to allow for a cage to go through the dash.
I don't see it as just a "look good" piece personally.
i agree that it isn't simply cosmetic. to do custom aftermarket guages and a decent switch panel in one of our trucks requires ALOT of work on the existing dash to make it look nice. try searching the images of threads titled something to the effect of: "where to mount switches???" and you'll find alot of people doing really ugly stuff.
additionally, if you are having to replace your dash pad - it costs about as much as this dash.
the dash opens up lots of options that the stock ones don't really allow for.
Most importantly, in my opinion, is installing aftermarket gauges. Factory ones that are 20+ years old are marginal at best for monitoring engine function.
any way to make the glove box water proof? Im thinking it would be a good place to mount an ignition box.
Personally, I'm interested in a roll cage for my 91 Sub. I prefer a "through the dash" design rather than an offset design. Don't really need a new dash and my instrument cluster is fine, especially in regard to controlling the EFI functions. If I was faced with tearing out my dash and cutting it up, this dash would interest me. Now if it came with a front roll bar, I'd definitely be sold.
