Oops didnt see that part. Thats odd. Whys oil up there?
Sweet Jess. and yes the front digs are cool!!!!!4wd works
Climbed the logs with ease. Gotta move the bumps down, and try to clearance the header to my fron drive shaft will not rub.
Needless to say Doubler is awesomeness!!! Front digs are awesome as well!!!
I need to figure out a new reservoir for the power steering pump as it pushes the excess fluid off the top, and when it does that it doesn't have enough fluid and the pump starts wining. Anyone that is running the stock hydroboost pump, and reservoir?
And oil is leaking from the top of my distributor, where the cap meets. I'm guessing there is a seal missing or something.
here is a pic of my hydroboost reservoir setup...I just made sure the rezy was at the highest point in the system (except for the lines to the hydroboost unit) The cooler I had to mount lower to keep it full, and keep it from draining back into the reservoir when it wasn't running.
Jess, not sure about a HEI, but the older dist. had a seal in the dist housing right around the pole piece, it was more of a grease well to keep the pole piece bushings greased....may have to pull the dist. and remove the gear, then pull the pole piece out to check the housing.
hmm seems I forgot the pic of the hydroboost reservoir...
Nice job Jess, are you keeping it now?
Yup.. I was just bummed on the house stuff and not finding what I want. Now that I have an accepted offer, I do not need to sell it.
and have a little over 2 feet of house so I think that should solve my problem.
Sorry, I just could pass that up, I'm guessing your house is pretty nice. 2 ft of house?Sorry, I just could pass that up, I'm guessing your house is pretty nice.
The truck looks good. Maybe you can finally take it wheeling now? So I guess this means you aren't moving to W michigan either?
Well if your bitchen bout it ill take it off your hands![]()
