Soft top ordered along with a 4” shackle flip from ORD. Decided to go with shackle flip instead of new rear springs.
I don’t think there was much of anything with straight metal on it. Them boys are known to take breaks and hit golf balls at the vehicles. HahaNo but I'll keep you in mind if I run across one. Maybe make a run out to pile of cars, where you got the windshield ? If you do let me know I would like to tag along.
Can you say “flux core”….
Flux core isn’t bad if you can weld to begin withCan you say “flux core”….
And works great in a windy area. That’ll probably work. Just for safe measure I’ll probably post the original weld pictures on the FB shaming pageNot my finest hour but it’ll do. I just burnt through what was there as I didn’t want to grind it and or burn it off. I’ll just replace that center 1 3/4 x 2.5 square tube down the road.
Please do and share the funniest comments lolThat’ll probably work. Just for safe measure I’ll probably post the original weld pictures on the FB shaming page
I don’t like inboarded shocks on a truck that would be on the highway. I would fix the stock setup.Question: what are your opinions on Inboard shocks?
either way I need to fab up something for the shocks. That plate on the side of the frame isn’t going to cut it.
