OK, first of all, I don't need any "I told you so's" on selling the spanner socket tool.
I just got back from the Dealer and they did a front end alignment on the truck. Brought in my Midas $50 coupon and they matched it so I thought, I'm good to go.
After about 1.5 hours, they came back and said it looked good but the Caster and Camber were out just a bit. Not enough to wear the tires but not "right on". They told me that those were not adjustable. I told them they are adjustable and that there is a tapered sleeve in the upper ball joint that could be rotated to bring it in line better and I still had one of the tapered sleeves back in my tool box if needed.
He went back to asked the mechanic and sure enough, it is adjustable but that would cost me another $110 for labor to install plus another alignment. He said that the caster/camber is typically non-adjustable in their typical front end alignment.
I figured I could at least install the tapered sleeve and then bring it back to them for a second check.....(if I only had that Spanner Socket to install this thing
). Oh well....I guess I might just have to buy one again anyways.
With that behind me....
After discussing with the service adviser, we concluded that the top of the passenger side ball joint needed to be moved "back" and "out". He thought one side was all that was needed. Looking at my sheet, the driver's side looks like it could be moved "back" as well.
So, if I got another tapered sleeve, I was figuring to install and then bring it to a shop for an "alignment check" for another before and after. Hopefully with the new tapered sleeves, I will be closer to the spec areas.
Sound like a good solution??
Finally, I don't remember where I pulled them from (upper or lower) but I had some tapered washers as well. Any idea if I could utilize these as well in the alignment?
Here is the before and after readings.......
