I use a smart relay. It is normally open, if it senses 13.5 volts on either battery it will close. This shouldn't be an issue. For me it is a small issue. I run a small solar panel on the AUX battery, when the aux battery is full charge the solar panel puts out 13.5v and I hear the relay close, the voltage drops the relay opens. I Have to disconnect the solar panel at times.
, 5 years ago
