And since doing the shock hoops, with proper uptravel, I've found myself getting into the firewall/wheel well more and more. I'll trim what I can and hope its enough, otherwise I'll have to put bumpstops on the BB15 list. (along with OBA and front cage to bumper)
If anyone is curious about tire rub. 1" body lift, 4" lift, 1" Zero rate, axle moved 1.5" forward. 38" tires that measure closer to 37. I love the look of my cut fenders but I didn't have to get as aggressive with the bottom, near the door. I did have one time while wheeling that my driver tire was so stuffed and turned driver, that I couldn't turn the wheel. I had to back up some before it freed up. I'll need an RTI ramp of sorts to check that out. For now, out comes the grinder again.
