Bought some hoses to finish things like map and PCV. I’m off all next week. Gonna try and get this thing lit off and if possible, driving under it’s own power.
That rod end threaded in far enough to that draglink? It doesn't look like a lot of thread engagement would be there...Spent two hours fighting the steering box. Went to put the ORD brace on and noticed this:View attachment 491814View attachment 491815View attachment 491816
Looks like a rivet snapped on the left side frame next to the box and the frame and crossmember have shifted and that’s causing the brace to be so far from the cross member. Great.
But I persevered and got the box mounted, lines connected, and pitman arm attached. Was going to try and do some vac and map lines but my temper is raging and that’s generally a sign I shouldn’t be wrenching so I’ll try again later. View attachment 491817View attachment 491818
Just heard back from MSD and the module failed. $140 to replace it.
And walked out to the shop yesterday to a puddle of power steering fluid. Looks to be leaking from one of the brand new lines but hard to tell. Probably gonna have to pull it and check it out.
