Be careful with using the AFR reading at idle, its not always 100% accurate if you have some valve overlap. You will find out, the target AFR surely isn't 20:1, so if the learn table is adding a bunch of fuel and it still says it's lean, then it's getting bad data. If it's getting better then you are good to go.I gotta do a couple more things before I can really drive it. Front shocks need bolted in, brake booster vac line, body mount bolts tightened, wires and hoses tied up, and at least the driver seat bolted in.
Also need to look at the tune. It’s idling at 19-20afr which is a bit lean even at idle in my opinion. My exhaust isn’t the best so I’m going to wrap the joints in foil and tighten things up to make sure there are no leaks.
