Ah now I see what you are getting at. I wasn't live. I had just pulled the SD card and was reviewing that.
Always download the global before doing that. I mostly don’t do live cause I don’t have anyone to drive it.Ah now I see what you are getting at. I wasn't live. I had just pulled the SD card and was reviewing that.
I’ve learned over the years with my Megasquirt, once it’s running good turn learning off. If it ain’t broke don’t fix it!First minor issue. Was driving around for a while today and it was constantly in the 20’s for learning. Get home and parked it and it’s idling at a 1000rpm and still in the mid teens learning. Didn’t see any obvious vac leaks. Gonna take a look at the logs and then let it cool and see what’s up. Was doing some reading on the Holley forums and got some things to check.
Keep an eye on the closed loop comp it will tell you how far the tune is off.Holley says the same thing. I transferred the learn to base and am gonna drive it tomorrow and see how it runs and if all is well I’ll shut it off.
I love mine, glad you talked me into it.The prodash has a fuel gauge in it and can also see all of the Holley stuff and data log in it.
A $1000 dash seems a bit overkill for a gas gauge haha.The prodash has a fuel gauge in it and can also see all of the Holley stuff and data log in it.
It will do more then that!A $1000 dash seems a bit overkill for a gas gauge haha.
The irritating part about this is I’ve got a sensor sitting on my work bench for a fuel pressure sensor. I’ve just been avoiding it because it’s been hot and the rzr has been taking up the garage space.
