My steering wheel is half way turned with my sheared center pin.Check the leaf spring center pin too.
My steering is 90* off but the tie rod has a nice bow to it.
I was thinking you sheared a rear pin?My steering wheel is half way turned with my sheared center pin.
Hey I saw that tie rod! I thought that was to clear rocksMy steering is 90* off but the tie rod has a nice bow to it.
Let's see I tried three different high pressure fuel pumps for the Command Center, two low pressure mechanical pumps, and an electric low pressure pump. I ended up buying a high pressure pusher electric pump to mount on the frame rail, and then purchased the backup for that one on my way home.Fuel pumps seemed to be the theme this year. At the peak heat of the day I could hear mine screaming.
Do it and never look back. ACdelco + TBI tank + sender = win
Are you running a fuel return on your Fitech?Let's see I tried three different high pressure fuel pumps for the Command Center, two low pressure mechanical pumps, and an electric low pressure pump. I ended up buying a high pressure pusher electric pump to mount on the frame rail, and then purchased the backup for that one on my way home.
I also just ordered an in tank fuel pump to fix all my problems.
Grand total 9 fuel pumps...![]()
The command center has a regulator and return.Are you running a fuel return on your Fitech?
I used the stock sending unit and fuel pump from a 97 suburban. This is in a stock 70 Tank. Works great after I made sure I had the right psi pump for it. Been running the same one for about 7 years.Do it and never look back. ACdelco + TBI tank + sender = win
My Fitech has an internal regulator and I run a return right off it. Might be worth looking into your model and seeing if it does the same.The command center has a regulator and return.
