So drove down to the farm store to get some nuts and bolts, died on the way.
Drove the rest of the way and home with out any issues, after letting it sit for a few minutes.
Drove back to the farm store because I needed a piece of steel.
Died at the end of my street on the way back. Pulled out the multi-meter to see if the pump had power, muti-meter is broke. So neighbor pulled me the 1/4 mile home. Started right up when I went to check it with the not broke multi-meter.
So .... put in the new relay ran it for a long time and took it for a drive no issues.
Not sure that it is fixedPump sounds louder now, not sure if that means anything.
So maybe it was a not-quite-failed relay. Worked just enough not to be the obvious problem.
