Blower Blazer Build
Surely the axle was cracked previous and just let go with the jolt of putting it in gear. The metal also looks porous to me even for a stock axle. IMO
You snapped a 14bsf axle shaft by putting it in and out of gear? :screwy:
Sitting apparently caused the brakes to rust to the drums or something. <snip>
The blazer didn't want to move for Matt. I traded him places and rocked it a little. BANG and it was free.
It was a little more than putting it into gear. It was in gear and I was giving it some throttle and letting off. Not a lot, but enough, especially being in low range. (basically like doing a brake stand). It would move a little too, so it was hard to see what was holding it up.
It snapped right were you would expect an axle shaft to snap (small diameter, edge of splines, stress concentration areas), and very consistent with other broken axles that I've seen. The other axle shaft looked fine.
I don't think it would have snapped a ff14 shaft though. I would expect the u-joint to break first, if the rusted section didn't bust free.
Starting to think about blowing this winter. I need to sand and paint the inside of the chute and line it with teflon (or something?). I'll take some cardboard up this weekend and mock it up. No idea where to buy it in SLC area.
