90'K5
I would suggest at least boxing around the shackle hangers. I bent the frame at both front shackle hangers when I rolled mine. I currently still have the stock frame, but no core support, the front is caged out like bgreen's above. I have fender shells hung off the cage. The rear is in the process of finishing the tube work and hanging shells.
I have a stick of 2"x4" that I'm planning to use as a new frame front to back eventually. Although I may end up linking it as well.
I still have the stock cab bushings and get a lot of flex in the body even with the cage tied to the frame. My cage is hard mounted to the stock frame with a piece of 1/4" plate to spread out the load.
