That arrived quick!
i got the front springs almost 15 years ago i think from a friend parting square bodys . he got them well used from a truck .
if i had to guess from all the info i have seen and read there rancho 4" lift and 6leaf pack . i have pulled 2 leafs and they ride better / flex better / sit a hair lower .
so if i was to replicate the stance i would do 2" lift range from these being so old / used / worn / flexed / snow plow weight .
this truck is sbc350 all iron / th400/203/205 true k30 and 250lb range of fisher snow plow frame work .
other k30
454 all iron aluminum intake / 4l80/203/205 true k30 and no plow frame yet has tuff country 3" hd fronts i purchased new and used 1 season .
all my leaf springs run ORD greasable poly bushings so no worn out poly or rubber deflecting the readings .
budget beater axle tube to bump stop frame mount is 11.25"
plow machine build axle tube to bump stop mount is 13.25"
hope this info helps @beags86
you had something about van tanks here. I didn't know what you meant.ahh i use van tanks . . . .
got 2 new 20 gal saddle tanks ready for install .
I know he mentioned van parts in a thread a couple of days ago but not sure it was tanks.you had something about van tanks here. I didn't know what you meant.
