Maybe try relocating the sensor to the head too. Like @ZooMad75 said, maybe your catching fluctuations from the thermostat that don't really reflect the real engine temp
Hmmmm ok,
Not even sure where to stick it in the heads lol. Can someone point me in the right direction?
I will say for sure 210 doesnt worry me. But when in the course of 2 mins at a light the temps climb from 206 to 212 or 227 like i was seeing that concerns me a bit.
I can say the flex fan does seem to help.
I also just plugged the gaps on the sides of my shroud to see if that helps at all. It will force any incoming air through the radiator.
I think ill pull the shroud and add some weather stripping foam and mount it again. Zero air gaps. And since my fan only has 1/4" to 1/2" gap around the fan it should really form a solid vacuum.
Btw i noticed zero sound or power changes eith the flex fan... go figure...
