Keep in mind that the top plate is different between the two different front ends. The diesel one for Nightmare could be a very rare one!
They said it cools better.For what reason? I did it due to cost.
I have my stock 454 idle at 24° advance. If you check a TBI350 timing at idle with the computer controlling timing, you'll see around 30° (if you're timing marks go that high).
There's a lot of knowledge gap about timing at idle. Vacuum advance should be connected to manifold vacuum for one thing. In essence the ported vacuum port promotes a hot combustion chamber at idle, this was done in the early emissions days to bandaid other problems. Manifold vacuum will pull in the vacuum timing on the distributor to boost you initial timing for a cooler combustion chamber at idle. Both ported and manifold pull in the vacuum advance at steady cruise, which is the other time the engine needs lots of timing advance.
As an example my 66 doesn't even have a ported vacuum port.
I just set it in there to see if it fits. Its back on the shelf.No added the other fan either.
One step at a time.....
